This pump will directly bolt on to your engine and you can then disconnect the wiring from the engine, You might need to fiddle with the A/C rpm sensor wiring to make it work, anyway, before you mount this pump make sure that the cold start device, (item with 2 coolant pipes) is actually working, try pouring boiling water through it and watch it extend,. when it extends the rpm drop to normal.
