sir as you can notice in the pic of 1st post im using cone air intake directly on throttle body there is no Oxygen temperature sensor..
what effects will it make?
rough idle, bad fuelling or what?
and what does STA signals tells ecu to do?
sir O2 sensor is present and in working order..
i'll get the codes with engine running..
and the run like champ,but sometimes rpms start fluctuating on idel, like up,down up, down.......and that black smoke problem
whats the best way to adjust TPS?
