Actually ... There is a difference of projectors ,So ofcourse the way I aligned mine is different !
Mine projectors are for H1 housing .... But they comes with the additional back plate which makes them H4 to be fitted without any alteration in H4 housing as well .....
Now the technical point .... The back plate of mine having the lock which was giving problem in rotating projectors to any way ... So I scratched it a bit ,Now it is rotate-able to where I want them to be ...
Then I rotate them ,Make the desired cut-off .... Aligned them vertically (City headlamp adjuster) and Voila !
P.S the cut-off point you posted is for Left hand drive (LHD) cars .... Mines are for RHD,So the Upper side cut-off is on left side !
I hope it explains the confusion
