Hello all,
I installed a new solar inverter Fronus PV-2200, with 4x 570w panels and 200amp battery. It's been just over a month now, and inverter is working fine when power goes out.
During the day its default setting was to use solar and utility power shared for the AC load. I read through the manual and changed it to SUB (Solar - Utility - Battery) and it was still using shared grid power.
There's MKS option in priority setting, and I searched online for it and found out that if I set to MKS, the inverter will disconnect the grid when solar is generating enough power for AC load. I changed inverter to MSK and for next few days when there was bright day, it would automatically disconnect grid and run the load on solar until evening, then switch back to grid (switch back volts for battery were set to 13.1, so it will not use battery).
Now this stopped happening even on bright day, I see full 190v on panels and PV is making ~1.6amps generated, my load is under 25% of max capacity of inverter, and output load shows as such which remains in 400w range. (no fans yet due to cool weather).
Any pointers, why inverter is not disconnecting grind now when there's full sun and it only did it for 4 - 5 days.
Thanks in advance.
