TVS Apache Engine Oil Leakage
June 18, 2008 by tvsapache
My complain doc no : JC No 38141
DEALER
SAR VSHAKTI AUTOS
Mehrauli road Nr. Kalyani Hospital Gurgaon
Phone no 4085154
Hi
as one of your customer care employee says that you go this time your bike will be services properly. I went there and ask for the same problem. Vibration in engine, engine oil leakage, Gear shifting problem. This time they do the worst. They put white solvent around the engine which is looking very uneven now engine color is black having a white solutions around it. This is the first time i have see.
I ask them if you are unable to do it then please send it some were else where the problem can be solve. According to him the engine has no guaranty and warranty they cannot replace the engine. They only put solvent every time. I could not understand how a solvent can stop the leakage. After getting heat it will again melt. It meas i have to come again and again to service center.
This is the first time i have see this type of solutions.
They have make my bike more worst .
Problem in bike :
1. Gear Problem - I have mention ever time that there is a problem in gear.
2. Vibration in Engine - The engine vibrate too much.
3. Shocker Problem - Every time then change seal of shocker and again it get the same. I have ask for change they says that it will cost you to change.
- Engine Oil Leakage – Engine oil leak but the says that its ok it will leak little bit.
