Car drives well. I usually don't go above 80 but in this speed range it's perfectly fine with ac. Even in the 2nd and 3rd gear when rpm drops to 1-1.5k and I don't change the gear tab there is no problem in the pick.
The sound seems okay for a below.
Oil reduces a little. I change it ever 8 months when the car has driven like 8k. I use shell synethtic 10w40. The oil at the time of change is 20-30 percent above the minimum. Level on the dip stick.
Total mileage is 100k almost. Bought it 5 years ago at 60. There have no been a single mechanical problem since I have had the car
Removed cng. Purely petrol for 5 years+
The only problem I have that led me to the investigation was a lot of smoke at start up and some smoke while driving. I aslos shared the videos above of the smoke.
The guy didn't do the wet test because according to him the piston rings were shot as the compression was so low. He didn't see the point of doing a wet compression test.
