i also want to clean (as well as the fuel indication in meter is not working) the tank, as my mechanic ask me that it would take about 1 & half to 2 hours..about cost.. it is 300/- to 500/- he charges me.
i also want to clean (as well as the fuel indication in meter is not working) the tank, as my mechanic ask me that it would take about 1 & half to 2 hours..about cost.. it is 300/- to 500/- he charge me.
thanks buddy for the timely reply!
Check your balance rod bushes and chimta bushes and if metter persists check the play in wheel's ball bearings.
The bushes and bearings i told afore cause such problems if tyres and rims are ok even at low speeds.
Balancing cause wobbling not shaking.
Do you face any decreasing of oil at dipstick.
@Baleno1300 Fog Lights (Japan) : 2500Power Locks : 1000Retractable Power Mirrors: 1500From where did you buy these above mention things?
Complete sets are changed.
Where did you see LE?
+1.
For how much $$ a kabli "kanghi" could be found from bilal gunj ?
It depends on the level of wear on your steering arm gears,if the demaged teeth are so blunt that they easily slips away from each other there must be grinding sound but if the level is lesser then the play thing will act upon.
I advise you not to do that because some times the gunk sticky inside the tank will be removed and in the long run you might have demaged the tank.Try to locate some honest filling station instead.
The gunk settled in the base of your tank is acting like a protective layer now.
Well i remember, you already have statred a thread in CNG related form so you might be much more knowledgeable about the filling stations in different parts of our country.
Yes you will have to chek the float guage inside the tank for that or possibly check the connections behind meters or worst the temp meter is out of order.
And for the people like you and only faith i would like to comment on,try octain booster if your fuel is not giving you satisfaction in performence and if your fuel is becoming the cause of jurks while driving then use injector cleaners before you go to dismental your tank or injectors.
Go to suzuki house bilal ganj,i have seen many with them and about the price they will demand four times greater,so its your skill now to do the business.
A good kangi should be around 2500. pk rs.
03334684371 Arif,Suzuki House Bilalganj.
no mate, i didn't face any such thing.
@Skill
All things from Rwp "Sultan ka Koh" of course.
