Update:
Got ELM327 and attached to DLC, 1st there were more codes, so i gradually corrected them to the last one Code 500 VSS vehicle speed sensor signal, apparently the ABS signal is not working the way i am using it, maybe i will use another method. By attaching brake pedal input signals, the engine RPM are corrected , now it idles at only 650 or 600RPM with ease, before it was around 1000, its getting closer.
Inshalla it will be okey soon i figure out the way to VSS,
More over its not getting Transmission fluid temperature also, so maybe will need some guidance here also.
