@Gliblastoma
Corolla 1.3 1295 cc, 1987-91, ,Engine Code 2E
ignition data
Corolla 1.3,
Ignition system type: El-i
Ignition coil make/type: Den/-
Supply voltage: 12 - Volts without ballast resistor
Primary resistance: 1.2-1.5 Ohms
Secondary resistance: 10200-13800 Ohms
Distributor make/type: Den/19020-11030
Contact breaker gap/air: 0.2-0.4 mm
Dwell angle: n / a Deg
Ignition Timing - unleaded: 5/800 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 5/800 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: O/S/F
Firing Order: 1-3-4-2
Spark plug make: NGK
Spark plug type: BPR6EY-11
Electrode gap: 1.1 mm
Fuel System
Corolla 1.3,
Fuel type: L/U
Fuel pump type/pressure: Mech/- bar
Engine idle speed: 800 50 rpm
Fast idle speed: 3600 200 rpm
CO level at idle speed: 1.5 0.5 Vol %
Engine Data
Corolla 1.3,
Valve clearance - inlet: 0.20 h mm (hot)
Valve clearance - exhaust: 0.20 h mm (hot)
Compression pressure: 10-13 bar
Oil pressure: 2.5-5/3000 bar/eng/rpm
Radiator pressure cap: 0.75-1.05 bar/type
Drive belt 1 - size: 9.5x985 KDB988 mm/type
Drive belt 2 - size: n / a mm/type
Electrical System
Corolla 1.3,
Alternator output: 30/2000 Amps/eng/rpm
Regulated output: 13.9-15.1 Volts
Battery: 12/60 V/Ah
Starter motor make/type: Den/0.8 kW
Other data
Corolla 1.3
Clutch operation type: Hyd
Clutch adjustment: 20-35/Pedal mm
Cambelt failure: Damage
Cambelt Part Number: 1356811052
Tyre pressures: 1.9(27)f 1.9(27)r bar (psi)
click me
