But you dont think it will give thermal shock as we add cold coolant and engine will be hot???
It worked @hasankhurshid29 now I am getting all live data. Initially it was not communicating with ECU but after entering this string it detected thanks for sharing this
Whuch app?
Bhai keya updat hai ap ki gari ki ? running fine ?
Yes check my last threads I have updated
Torque Pro
My Rides in past ... But always a 2.0D Saloon
Uploading... pics not uploading
try again
did you change gear oil? and how well ou car is running after putting back tstat valve?
Car is now achieving operating temperature and heater also working very good. Atleast I am satisfied that no harm is causing. I also took car to Dealership they said gear oil is ok but there is a jerk when changing from 3rd to 4th. May be its default settings.
adjust the clutch cable
Rest is fine i.e 1st--->2nd OK 2nd--->3rd OKOnly there is a jerk in 3rd to 4th i.e overdrive
ABS does not seems blinkng now but it is not getting connected... will check again.
Have you added the string in Torque pro? and leave the protocol to automatic search
Attach the picture and wait for some time will the picture uploads 100%
yes i have added the string and kept it on auto search... will try some other time and will seek your help in case of issue,
i have small blue colored device which works fine for 1.3 corolla and honda city.
for an auto car ?
If i am not forgetting once u said gear oil has burn smell. is it gone now ?
According to them no burn smell and color is ok but I will still change it
