It will be too expensive, diesel engine compression testers are expensive i heard about
I bought from AliExpress two years ago for Rs 8000 with delivery
I understand how the contraption works. and no , it was not my mechanic, nor do I need to import the device. lastly, 2mm ... NO !
2mm is the plunger preload.
Dear @Xulfiqar can we remove CSD from toyota 2C for cleaning with vinegar without any cherkhani with pump? I mean if i remove CSD is there any chances of diesel fuel coming out from pump? Or it is sealed?
Sir pls have your thoughts, as i am engaging CSD back to work , but this one issue about diesel fuel leakage, will there be any if i unbolt CSD???
Whats your location and how to contact you about dial guage adapter?
