The big one at the bottom is crank shaft pulley. Oil pump is located behind it (behind the plastic panel and timing belt), pump doesn't got any external pulley.
The oil pump is behind the crankshaft pulley bro. Crankshaft pulley is the biggest pulley than all others
Assalamualaikum bro how r u?
Wailaikum Assalam ALLAH ka shukr And you?Here check it out yourself
AlhamdulilahOk bro
Assalamualaikum bro how r u.Today I got the car checked by mechanic.He said the bolts of crankcase were loose.That was the reason of leakage.He tightened them and said it's fixed now.Will update more on it in future.
Wailaikum Assalam.ALLAH ka shukr how are you?I don't think so. But do update about it.
Alhamdulilah.I will update in few days
Also power steering fluid was leaking.Fixed that too.
Assalamualaikum how r u.My car,s alternator wire has little corrosion on it.How can I get rid of corrosion
Wailaikum AssalamALLAH ka shukr And you?Clean it then after fitting cover it with grease so it will not catches rust again.
AlhamdulilahOk thanks bro
Eid Mubarak bro ️
Khair Mubarik bhai.
Bhai can leaking power steering pump be fixed by replacing it's seals?
Yes it can be fixed.
One guy is asking 2500 for replacing seals of power steering pump.Is price ok? And does replacing seals usually last or issue arise again?
Sorry no idea about price.But if done properly it will last.
The price of power steering seal is 300 n i paid 300 as labor here in taxila
Here one machinest is saying 2500 but I will look for other people here.btw thanks for the idea and do u have any pic of seal
