To all the fans of indus corolla here, my best regards. does anyone here has owner manual of 2.0D (indus shape), lost mine a while back in some shifting. i just need to confirm a small thing, what are the recommended tyre sizes and associated tyre pressure PSI. back than toyota PK didnt bother putting the label on side door panels or pillars. i remember stock (non Alloy) steel ones in 2.0d were 165/ 70 R13 with steel rims & General tyres (i kind of have the spare wheel - not used) and didn't check but should be this). i shifted to 185/70 R13 with H speed rating & 86 load index at the first tyre change and ever since m stuck to this profile with 30 PSI pressure in all 4 tyres.
unfortunately, its hard to get this profile anymore in R13s or even dropping to 185/65 R13 doesnt help as S or lower speed rating or they have pathetic load index (too low) , between any lower speed or load index is not ideal for 2C engine in front....
just recently managed to get a year old (manufactured) Yokohama A drive in the desired specs but they are really out dated in terms of tread pattern and performance, so planning to shift to rim size 14 hence need the recommended tyre size and PSI....also till i dont shift to 14s, just wanna know wat PSI is recommended for 185/70 R13 profile.... and overall range specified in the owner manual for 2C engine in front. thats a damn heavy engine for indus hence PSI and tyre profiles might differ from petrol versions..
Thanks in advance for your support.
