My bad pumps. Like Xli etc.
I also think xli one will be good as finding geniune one in good shape is difficult.
Yes. Or you car go to kacha stop in pindi on weekend to find a good kabli fuel pump.
Right now I,m in Peshawar.Will check from shoba
Assalamualaikum bhai how r u.The wheel bearing of my car has gone bad.Which type of wheel bearing should be installed.I saw online koyo company and nsk bearing.Is it good?
Wailaikum AssalamALLAH ka shukrYes both are good and NTN also.
Ok bro thanks.And can anything beside wheel bearing cause growling sound when speed is increasing
Brake pads and shoes can also cause noise.
Ok
Any price idea.
Probably 4-5k each. Or maybe more.
Ok.And what other things besides fuel pump can cause misfiring and stalling.And car refuses to start but if we leave for a while then it starts.
Misfiring can be caused by plugs, distributor, distributor cables and even injectors.Pump can cause that or bad distributor coil.
Today got the fuel pump checked.Electrician said it's working fine.We got it changed in Islamabad because car had difficulty starting.It was working fine today when coming from mechanic to home but later I was near my home and first it had a little hesitation then it turned off and refused to start.Then we pushed it and it start after that took it home then it was studdering.Now it's parked.
Need to be sure about few things.Fuel pump again, distributo coil and wiring. A loose relay can make car struggle to start.
Ok will checkAlso there is relay clicking sound near headlight switch (stick,)
Today got it checked.I noticed that clicking sound was from cng button.And car was continuously shifting from petrol to cng.Then electrician said wiring of kit was connected wrong.Actually mechanic removed kit yesterday for power steering pump fitting(Got 1nz one). Steering is now good MashaAllah.Now there is no missing.Also got wheel bearing changed today with FHD one.Noise is gone now.
MASHALLAH great.Cng problem solved?Cluster looks good
Yes Alhamdulilah all problem solved.
