Yes 5efe will work.
First be sure W pinout of ecu is connected to check light of the meter
Now turn the Ignition switch to On position where speedometer lights turn on
Now short the TE1 pinout wire to the ground, as soon as you ground that wire ecu goes in diagnosis mode and will remain in until you break the connection.
Check turns off and blink if there's any code
Count the blinks ,
It would be in a pattern with pause. Great pause mean another number.
Eg blink - pause of 0.5 sec - blink -- pause of 1.5sec -- blink -pause of 0.5 sec - blink and sequence repeats , this means 22 code
