Bro its 2017 model car just 2 years and 50k on odo ,
Well tonight i flushed the system following that pw thread , oem way to change cvt fluid of grande***
Approx extra 0.5L was poured as compared to Previous Quantities (Drains and refills) ,
After the process completed , Also performed pressure calibration and Memory reset ,
The SLS high and low temp is also improved ,
It shows 3.5 on high and 0.6 mpa on low.
High one is little better then before ,
Will test drive tomorrow and share you Details.
The worst part of this all scenario , 2000kms ago when i changed cvt oil by chamber method , The mechanic didnt adjusted level on 35 40C and after that change i took car on 1000km northern trip with fully loaded car and luggage.
It was performing fine there but As soon as i got back to Lahore it started giving that jerk. I also used M mode in Uphill and downhill drive (Half breaks and half Gear stopping) Didnt abuse Tried best to drive carefully.
