You can put 15” rims in passo but you should follow the following rules:
1) The total wheel diameter should be as close to stock wheel as possible, not exceeding by 3%.
This means that you should use low profile tyres accordingly.
2) Proper offset should be selected as per recommended range.
I have installed 17” rims in Vitz with excellent results after proper calculations.
