without a problem you can use same transmission. You only need engine with ECU wiring & sensors.
your vehicle is also knowns as Toyota Platz XP-10 it has several engine variants means there is not cut weld requirement to swap an engine.
1.0 L 1SZ-FE I41.3 L 2NZ-FE I41.5 L 1NZ-FEthese 3 engine option are common for every market.
thankyou brother
i thankyou for your insightful information ....1.0 L 1SZ FE i didnt enjoy much
so the other options are either 2SZ,2NZ or 1 NZ 1.5L ....which would be better option in terms of performance and fuel efficiency ,Thanks
