Have you ever disassembled this new gen engine????
It has so much tight clearence in between crank shaft bearings and piston side side skirt and cylinder bore. Plus it has narrow oil expander rings in which only 0w20 penetrates well so using high viscosities in a healthy engine only use lowest viscosity available on oil recommendation chart.
Always remember to choose the lowest marked viscosity on oil recommendation chart.
