i discussed it with 1 new electrician.He asked me about the speedometer.its speedometer is not original its from a toyota. prebious owner doesnot know which toyota. Now its speed gauge does not work but rpm does.owner told me that he could not find the cable for the speed gauge.So the electrician said, that this toyota meter is designed for ABS cars and since there r no ABS in this car, hence its not giving proper signal.so this is the reason when u apply brakes the engine shuts off. he told ,me to get it scanned to be sure if scanner gives speedometer sensor error.
Now i need ur opinion if he is right or chawalein mar raha hai? if it is true what could be the solution? Again for people asking for scanning, he did not have a scanner. Noone has obd 2 scanners. they say they have regular older scanners. will those be good enough for fault diagnostics?
