I think there is no smoke puff in cold start, a little cold start smoke was in naran but gone after seconds. Causing due to cold weather i assume.
And to be specific which valve? A month back it was leaking from gear oil seal and engine oil seal, both replace so now no leakage from there.
Also, if you are from karachi do you know who could rebuild. I understand the reading below is 160psi is not good, any criteria for higher reading or we can go at any range higher?
