The actual brekin is completed.in first 20 minutes of first start and its completed on road.
THE 9 hour procedure is for engine general safety and load condition calculations. AND remember its not on normal odle speed we are talking about some serious high rpm ranges where if you apply those conditions on a normal engine it would seize or damage the parts because of excessive heat and load. THE 9 hour procedure is initiated in controlled environment where we had to maintain the standard temperatures of engime oil and transmission fluid which if left unattended could rest in complete.failure becaise there is no airflow passing below the sumps as in normal driving.conditons on the roads.
THE process is not for normal persons because they will end up in destroying there engines.
SEATING of rings in cylinder bore breikin is completed.on road right after the engine start and its a hidden procedure.not.shown on video....
