Hi Guys,
I need a bit of advice from the honda community.
Yesterday i went to visit a Honda service centre to get some work done. It was basically a a 40,000 fixed service. Paet of that service was that the valve cleanrance would be checked and adjusted as per requirments. I picked this option as i had recently purchased the car and i wanted pieceof mind that all the major servieable components had been done so.
I left the workshop, slighlty dazzled withthe bill at 72,000PKR - they found pads were low (which i agreed), coolant flush was required which i was happy to go with, but the cost wasnt made clear if im honest, i was expecting much less then that final pill they fed me, but i swallowed it.
The reason i picked the service package of choice was also because i could see the valve cover had a slight oil seep towards the back of the block - behind the oil filler cap. Nothing major but none the less it was seeping slowly and i thought why not get some work done in addition to the cover. I went home and something just didnt sit right in my head - i felt like i had been taken advantage off. I inspected my valve cover, and behold, the oil seepage was still there and the white silicone around the valve cover was not fresh at all, so i can guarentee that it hadnt been removed. I am a vehicle technician in the UK, so i know my way around a car a fair bit.
My question for you guys is, to the best of my knoweldge from working on german cars, valve adjustments require the valve cover being removed on the top of the engine (the black plastic cover with the VTEC sign) . I want to confirm is that the case for the 1.5L turbo 2016 model? If it is the case then i know i have been lied to and robbed and i will be taking swift action, but before i do go in all guns blazing, i wanted to confirm my susppicions from those who know the vehicle better.
Thanks again guys
