the 15amp fuse is there to protect stock wiring and relays in the circuit.
the wiring might survive from the higher rated bulbs...MIGHT. But the relay will probably be damaged. That is replaceable too. BUT, more watts = more heat; and in a plastic housing it will be more destructive than beneficial...and then you'll need to replace the headlights altogether.
