"Which high end components? <hr style="color: rgb(199, 226, 240); background-color: rgb(199, 226, 240);" size="1"> Guys which of these is the best component system. Budget is around PKR 40,000. The setup is for a civic so please keep the mounting issues etc in mind. There would be no subwoofer in this setup (so good bass response from comps is essential) and coaxials along with front components would be used only. Dynamat Extreme dampening on all doors. HU is a Pioneer 4250DVD
1)CS 265 X-Plain Pro - Rainbow 6.5" Component System
2)Iridium 6.2 - DLS 6.5" 2-Way Component System
3)165KR2 - Focal 6.5" 2-Way Component System with TNK Tweeter (Although international price is higher, they are available locally for around 37,000)
Which ones do you suggest?"
Wow what a lovely thread it is ... Mani, i must recommend you to get FOCAL component, i have found them the best all rounder hiend component. Other hiend brands like Hertz, DLS, Rainbow, Iradium and Polk SR are quite laid back however focal is the only one which rocks on all type of music frm pop to rnb from classical to bangra you can also use focal for SPL and for ultimate SQ setup.... Apart from that build quality of KRX or KRX2 is stunning and yes the response of midbass is amazing too.
Do not spend money on Hi-end Pre it doesnt make difference apart from millions of setting which is not useful, since i have P88RS and i ahve compared it with other models of Pioneer with 4v output and they sound the same. Yes if you want to compete in competition then you need one otherwise no need to spend money on it...
Spend most of your budget on speakers, never compromise on speaker since they are the solely responsible for output.
After your speakers, set budget for good hi-end amp and for that you need to get good quality amp of MAC,Sinfoni,luxman, Nak, PG, Zapco, TRU, etc
Now sub is waiting for its turn. Yes after these two you can get good quality sub provided if you feel the requirement of it or not.
Do not waste money on rear fill, stage always appear on front not on rear.
Now the last one is pre and good quality of copper wires with the right guage.
yes, Fitting is important and with proper deadening makes a difference in sound.
You can also ask STJ about it and he is one the most experienced in audio both( SPL and now in SQ) setup...
