Remove the right side caliper:
Remove the left side caliper:
Loosen the four pinch bolts and the axle:
Pull out the front axle:
The front wheel is out:
Break the bead:
And dismount one side after the other:
Dismounting completed:
Confirm correct rotation for the new tire:
Push on one side first:
The other side takes a bit of muscle and persuasion:
New tire mounted:
Check balance:
New front tire mounted:
Loosen the rear pinch bolt on the right:
Loosen the axle:
Remove the brake torque link and remove caliper while sliding the axle out:
Remove ABS sensor:
The shaft drive splines need lubrication:
Breaking the bead:
