Malik Bhai is behtar hy k total use karo. Acha oil hy
No doubt
U r right but a guy at liquimoli store islamabad told me that if u start using a higher grade oil then moving to lower grades later will damage ur engine. Seals began to leak and bike will produce too much noise.
Nahi bhai aysi koi baat nhi. You can change grades whenever you want their is no such issue.
No brother aisa kuch nahi hota if api is same or higher than recommend but we can't use lower api that can damage engine parts. I used meguin and believe me nothing happened to my engine. Its pick is fast and gears are smooth
Btw wthts reason of connecting capacitor bank with battery. Kindly share the benifits and procedure too. Capcitors can imrpove p.f and pluse output. Whats ur reason?
Malik api SM myn kuch talash karo. SL is obsolete and we are still stick with SL grade. Between SL is the only cheaper solution in oil. SM must be expensive
Ly dy k kixx or zic hi bchty hyn pakistani market mai.
Mare reason yeh ha bhai g k mai nay 2 horn lagay hain snail. 4 ampere each. Plus 40 watt ki headlight ha and fog lights b install krni hain 30w ki.. overall load increase ho jata ha battery pa. To battery ki support k liay capacitors install kron ga
Chota sa generator v nal rkho malik sb....
Hahahah
Aur yeh donoo gandey oil hain. Personally I don't like zic and kixx both. Donoo oil brands myn counter fieting bohat hy. You never know that you used original or fake. You will come to know only after engine started smoke.
Capacitors lag gay to power ka koi issue nhi rhay ga bro
I thread k members ki tarap lagan or effort dekh k mje yaqeen hy k hume acha oil zror mile ga. Keep it up frnds.
I know dear but just want to know for knowledge. Best of luck for ur work. U r related to electronics i think?
Bhai itna shashka? Are you Pathan or malik? Just kidding... Pathan loves to apply sucks cosmetics which you are fitting on your bike.
Yehi cosmetics Bhai ji yeh special horn aur SMD. Samney waloun ko andha aur behra karney k liye kafi hain
Haha. Kabi kabi zarorat parti ha bhai in ki b.
Choro g zemco ne thamaka kr dea hy aaj new bike launch kr k.
