Sir
You should look out for Bridgestone ER30 and Kumho KH11, they are premium tires, if you cannot find them, try Bridgestone GR80 or GR90.
Else look for Yokohama Decibel V550 if not available then Db ES501.
Tires get punctured when the DSP of P90 tries to do the time alignment, just kidding.
Just follow the traditional rotation pattern of tires after every 5K kms, 2.0D has more engine weight on front, front tires wear faster, rotate looking for their direction of tread and keep them clean and out of small stones from tread, use a good tire polish like Sonus and P21S wheel cleaner.
Pirelli P6000 are sports tires, not recommended for 2.0D and hard surfaces, will not last long then 50K kms, I replaced 2 front tires for 6,200 Rs in my 05 PROSMATEC, lasted 5 years and 53K.
Yoko C drive are good cheap tires, but nothing special.
Regards
