I tried again, not willing to came off.
This type of seal is for warranty protection. It does not comes off. It is removed by tearing it.
Use IPA or Gaoline (Petrol) let it seep through the curve, it will help clearing the saperation anxiety between the 2 surfaces
@Hassan1991 bro where to find this
Those plugs not going be locally available.Search on ali express. You can find them with pins hopefully.
check this (last option) is it the same?https://www.aliexpress.com/item/1005002553659849.html
should I order? deliver hojaye ga ya rasty main he na reh jaye
Looks sameYes ho jae ge.
thanks bro
Use H bride circuit with enough amps of FETs to drive motor bidirectional
I am thinking to add grounding to my house, i have determined that i need to use 8 AWG wire, but am unable to convert it to normal Stranded Wire size, i need help
@Hassan1991
You mean earthing? Converting chart.
Yes.
I have searched a lot, but i am not able to convert them like this "3/.029"
How much deep you are going to dig and place a metal rod?Here check this.cable_sizes.pdf (84.4 KB)
I will use Ke power pole ground.
I have seen this PDF, but am unable to understand it
3 is the no. of conductors and 0.029 inch is the size of each conductor. Total gauge be like the multiple of 3 conductors.
Is there a 220v relay available in market that once its triggered and then power is removed completely, it still stays ON for a certain time e.g. 1-5 seconds?
I need one of those... I searched for them in the market (Peshawar) but couldn't find where they are available... Please tell me which one is better, and are the price ok on w11stop shop online?
Yes. Available.
If a digital temperature output is not what you are specifically looking for, either will do. Even though it seems pricey to me,
