that is only possible with
1 the system is not coming up to temperature
2 you have big leaks in the system (when the needle reaches normal point, get out and try to squeeze the hose pipes, they should feel tight with pressure in them, that is normal system pressure of 13 psi. If yours are soft then you have a problem.
