Much appreciated, however, the action must not be against stock, OEM HIDs, LEDs or Halogen Bulbs, but against the use of High Beams!, irrespective of bulbs category.
Sometimes, I do not understand that what has gone wrong with the people here? that almost every other person is using High Beams in city, Highway, etc. for no apparent reason! I have been driving cars continuously since 2017, and never used high beams, ever! (Never felt need of it anywhere) The light is so bright that if you are travelling from opposite direction, you suffer, or if that car is travelling behind you, you suffer! and you can't even look in the back view mirror due to ridiculously bright light.
I personally think that action must not be against OEM, factory fitted lights, e.g. vehicles designed for HIDs, LEDs and Halogens should continue working accordingly, but on modifications; using aftermarket non-compatible accessories, using HIDs, LEDs in vehicles designed for Halogen bulbs, and especially, High Beams!
If anyone is driving his / her car on high beams, driver must be immediately heavily fined and punished to sit before his / her car with lights running on High Beams, and continuously look in to the lights, for at least 3-5 minutes. Only then, people might "Sudherr jyein"!
