Installing cruise will make you remove entire dash, lay wiring all the way to ECU, brakes relays and control, etc and you will have to change instrument cluster (which will have its own mileage, different from your existing) and then you will have to do jugar and reverse the car mileage. In reborn, car mileage count is stored in instrument cluster for some reason.
