Thanku so much sir for the concern....appericite it :)the problem is solved and as i was thinking it was coz of faulty FPRbefore i reached there they(mechanic and electrition) changed every thing plugs, plugs wire, distributer, ecu, fuel pump, injectors, MAP sensor, TPS, and what not....i reached here and told them to change FPR and they were like "sir ya kabi kharab nahi hota"and started there diagnosing again....they changed the whole wiring, wired all the sensor openly and place ecu in the hood and there was no single difference in the behaviour of car...i insisted them to change the FPR again like "yar maray kehnay pa ek dafa badal k to deekho" so they finally changed it and car was back to life...and then everyones mouth was shut....
there was no mis firing...and sir it was not exact 4K the problem startes as soon as we push the accelerator a bit fastly...but this was only hapening on moving car...on standing position it was going till fuel cutoff limit...
it was ideling was perfect..and there were no error codes....
