Hassantahir2 brother Today i noticed that while comparing both the engine oil and drained oil (gear oil) the engine oil was leaking, under the hood the oil is leaking from the chamber where it falls to the exhauste pipe so i think its the engine oil which is decreasing not the gear oil and the good part its leaking from the chamber i think its not a big job to replace that seal? i will spend 800-900 on that leak stop its better to replace the chamber seal?(i will confirm it from a mechanic too but im damn sure its leaking from the chamber the oil is not coming from the cv joint also...)
Now i need your help that what will be the labour for changing the chamber seal?does the exhaust is removed?whats the price of seal genuine(best quality name if possible)?please suggest me a good silicon(name) ? can you tell me a good mechanic in rawalpindi?
Please reply thanks
