Hassantahir2 bro yesterday again changed the seal 2 times one with kabuli chamber and one with my original one which is lready fitted but the leak was the same...
he was showing me that the engine where the chamber is fitted is not fully plain very little bit worn which needs to be surfaced but when i checked it myself it was not much a difference and at the end he was saying ap ki main seal ka he masla hai....wth?yar samne chamber sa saiim a rihi hai drops gir rha hai ya muft ma bkwas kr rha hai i think ab us ko kuch samaj nae aya kya karna hai is lya seal ka bol deya mene engine oil change kr deya hai 20 50 use kiya hai filhal our shell wala banda ne bhi kaha tha chamber leak hai seal ka koi mae masla nechay se bhi mene dekha tha
150 seal rubber type thing bronish type in colour he was using almost 3 times used
Transparent silicon
Once he also tried magic at that place which was uneven but did'nt work (with kabuli chamber)
Whats the problem with this chamber?
Yar koi permanent solution bata du please even if costy im tried of opening it again and again between is mechanic se pehla maine apne mechanic se is ki leak band krwae the and he only used silicon white colour it worked for 2 weeks i guess but i need a permannent solution
