This is the sensor brother. Got this frm Google. I dont know about Lahore. Someone from Lahore will guide you. But this is thr sensor.
Camshaft Position Sensor
The camshaft position sensor measures the rotational position of the camshaft and transmits that information to the engine control computer.
Symptoms of a Bad or Failing Camshaft Position Sensor
Problems starting the car
Engine may shut off or die intermittently
Engine may misfire or hesitate on acceleration
Check Engine Light may illuminate
Camshaft Position Sensor Related Repair Advice
The camshaft position sensor is commonly mounted on the cylinder head or timing cover; on some older engines, it is mounted inside the distributor
Whenever a camshaft position sensor is replaced, be sure to verify the alignment of the timing belt/chain to make sure there is no fluid leaking onto its mounting area
Always use a factory OEM camshaft position sensor and be sure to check for any relevant Technical Service Bulletins (TSB), necessary software updates, and re-calibration procedures
A camshaft position sensor code isn't always triggered by a defective camshaft position sensor. It can be triggered by other issues, such as a worn timing belt or timing chain, or a defective ignition module, crank shaft position sensor, or mass air flow sensor.
