Did i said O2 Sensor????
What it has to do with AC compressor??
BHAIIII! WE ARE TALKING ABOUT YOUR AC ISSUE.
The OEM AC Compressor of your PASSO had over load and over temperature tripping relays which in this Kabuli DUET Compressor already bypassed by the USTAAD JI thats why it goes on working without tripping and car remains heavy all the time with the feeling of more chilled cooling. Eventually this compressor coil will over heat too and it will die eventually.
Mark my words there is no problem with your car.... The problem is wrong compressor you have installed mistakenly. (The compressor is not heavy, rather its relay is also bypassed so that it goes on working without thermostat function)
