Page 1 of 101 1231151 ... LastLast
Results 1 to 20 of 2006
Like Tree1001Likes
Thread: Motorcycle Engine Oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Motorcycle Engine Oils
    Aslam Alikum, Immediately seeing the title you may have said this oh not again again one more thread
    for engine oil but guys please bear this one too purpose of creating this thread is to share the range
    of motorcycle engine oils available in market and for this i want your valuable co-operation as i would
    share engine oils & their pics which obviously will show the specification but i have access to only few oils
    which i have used or which are available in my city
    i can't access all engine oils so that is why i request all of you if you have used an engine oil or you have pics of
    bottle you should share here & share your review about that particular oil
    Your sharing matters alot as i alone can't collect all info about engine oils available in market
    As i just said in last line of first paragraph your co-operation is important in helping me out
    to collect info about engine oils available in market but also i need your help in Engine oils subject As i am not expert in Oils
    if we search on net this subject is too deep so want to know your info about these important terms in engine oils
    this thread will be useless if it does not have any details info about specification terms
    so kindly if you find some good info on net share here
    *API
    *JASO
    *Viscosity
    *SAE Viscosity Numbers 10w40,20w40,20w50 or SAE40
    *Single Grade & Multi Grade
    *Mineral & Synthetic/Semi synthetic
    Etc notify if there are some other important terms
    The Sole purpose of this thread is to collect info about engine oil available in market
    *Specifications/price & *Picture
    ^Sharing some basic info which i know as par my bike
    API in simple word an company which gives certificates of quality to engine oil
    so always look for this API label oil but some manufactures recommends JASO
    But most motorcycle manufactures in pakistan as the big one
    AHl recommends to use engine Oil with API SG,SF,SE or higher grade
    you should look your bike manual for the details about your bike
    Viscosity of oil is shown in the SAE numbers
    most oils nowadays available in market are multigrade
    first number which is followed by W (winter) shows the oil viscosity at low temp:
    lower this number thinner the oil be at lower temp:
    2nd number shows the viscosity of oil at high temp 100c: higher the number thicker the oil
    20w40 oil will remain less thick at 100c as compare to 20w50
    my bike manual says 20w40 is good all rounder for pakistani conditions
    but depending on the temp user can choose which oil suits engine more
    Now Lets Start Sharing Some Engine Oil Brand Which I Know Or Remember
    Shell
    AX3 20w50 0.7lt & 1.0lt (Pic on post #3)
    AX5 15w40 1.0lt (Pic on post #234)
    Caltex
    Havoline 20w40 0.7lt (#1986)
    Havoline 20w50 1.0lt
    Castrol
    Go 20w40 0.7lt (Pics on #146)
    Active 20w50 0.7lt & 1.0lt ( Pics on #155)
    Gtx 20w50 1.0lt (Pics on #357)
    Atlas Honda
    Atlas Engine Oils (Pics on #948, #1054)
    Yamaha Lube
    Yamalube 20w50 (#1727)
    Servo
    M2 30/40 0.7lt & 1.0lt
    M5 20w50 0.7lt & 1.0lt (Pics on #14)
    Dyl Lube
    Dyl Lube 20w50 0.7lt & 0.8lt & 1.0lt (Pic on #4)
    Suzuki SGO Oil
    Suzuki Genuine Oil 10w40 (Pic on #106)
    Zic Lubricants -
    (Offers Online Purchase From Official Site)
    Zic M5 20w40
    Zic M7 10w40 (#1557)
    PSO Oil
    Pso Blaze 4t 20w50
    Total Lube
    Total HI-Perf 20w40 (#1233)
    Total Hi-Perf 10w40
    Master Lubricants
    Master Xtra 4t-MCO 20w40
    Imported Engine Oils
    Kixx (Korean)
    Kixx Ultra 20w50 1.0lt (Pics on #154)
    Kixx Semi Synthetic 20w50 (#1406)
    Liqui Moly (Germany)
    Racing 4t 20w50 1.0lt (Pic on #11, 219. 302,
    Racing Semi Synthetic 10w40 (#1244)
    Repsol Moto 4t 20w50 (#1270)
    Valvoline Champ 4t 20w50 (USA) (#1040)
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Post Reserved
    Zic Old Series
    Zic Synthetic 10w40
    (Pics on #25 #863)
    Zic 20w40 (Pics on #945)
    Zic Semi Synthetic 20w40 (#1211 #1275)
    Atlas Honda Old Packing
    AHl Engine Oil 20w40 0.7lt, 0.75lt, 1.0lt (Pics on #52)
    Total Old Packing
    Total 4t MCO 20w40 (#603)
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Shell AX3
    Motorcycle Engine Oils -1241464
    Motorcycle Engine Oils -1241465
    Motorcycle Engine Oils -1241466
    Price Around 250-260 for 0.7lt & 350-360 for 1.0lt
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Default DYL Lube
    API SG, JASO MA, SAE 20W-50, Mineral Based.
    Used it mostly when i had Junoon as it was available in proper quantity packing and i was contented with its performance.
    Used it multiple times with draining interval of 1000Km. At 1000Km, it gave the feeling of loosed viscosity and getting quite black in colour, thus justifying changing it at 1000Km.
    Just found on thing little fishy about it. This oil is provided to DYL by Shell as you can see at the bottom of bottle. Now shell also provides oil to AHL. On DYL bottle it is mentioned as "JASO MA" certified, but on AHL bottles it isn't mentioned, kind makes me concerned if DYL Lube really is JASO MA??
    Ansee's Avatar
    Feb 2013
    Rawalpindi
    342
    27 Post(s)
    2 Thread(s)
    Quote Originally Posted by gull_s_777 View Post
    Just found on thing little fishy about it. This oil is provided to DYL by Shell as you can see at the bottom of bottle. Now shell also provides oil to AHL. On DYL bottle it is mentioned as "Jaso MA" certified, but on AHL bottles it isn't mentioned, kind makes me concerned if DYL Lube really is Jaso MA??
    You cannot trust AHL with that either.
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Oh no another thread about engine oils
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    API SG, Jaso MA, SAE 20W-50, Mineral Based.
    Gull bhai excellent share & very properly shared
    Guys please share the way Gull bhai has shared his experience
    *Give title to post
    *Few Detail Pics
    *Your Experience
    Gull bhai yeah shell is providing oil to AHl & Dyl
    bro Shell there own AX3 is also JASO MA certified
    so may be on special demand of AHl they are not giving JASO MA to AHL
    as there bikes are API SG etc & this is what they recommend to use
    Quote Originally Posted by SyedMoazzam View Post
    Oh no another thread about engine oils Motorcycle Engine Oils - smiley smile
    sorry bhai
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    Quote Originally Posted by amjad635 View Post
    hmmm, may be.
    I think for grade SG and older grades, JASO MA doesn't matter anyway. SF/SG are safe to use in wet clutch environment even if they aren't JASO MA certified.
    But grades newer than SG, like SJ/SL must be JASO MA if you want to use them in wet clutch bikes. This is because these newer grades contain friction modifiers which aren't good for wet clutch. So while picking up SJ/SL grades, must make sure that they are JASO MA certified as well.
    humayun990's Avatar
    Dec 2012
    Peshawar
    45
    107
    7 Post(s)
    Amjad bro,
    Please search about shell ax5 15w-40 ( Available in company operated shell pumps) the best ever i used for 100cc engines, in winters as well as in summer.
    reliable upto 1200 km with best sound and pick ups, the engine feels light and cooler.
    Geo aur Genay do
    shazimzahir's Avatar
    May 2013
    Select City
    35
    3,259
    44 Post(s)
    4 Thread(s)
    Dear its really informative thread. But i think it will be good idea too also Add copies and counterfeits products available in market, as i hope many of us have experienced fake oils packed very intelligently. so how to identify the packing's and oil that its no 1.
    Regards,
    A Long Way Ride without a destiny on a Long Road is food for true Riders soul
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Liqui Moly Racing 4t--SAE 20W40 API-SG-SJ-SL
    After experimenting on a lot of oils AHL,Caltex,Kixx,Shell AX5 i finally settled down on Liqui Moly
    Reason:::Made in Germany/packed in Germany//Imported from Germany;;the most trusted oil company in europe with more than 50% market share.
    One of the best qualities of this oil is that it never looses vicosity even after usage of 1700Kms,,The drain interval is dependent on the make/model,,FOr CD-100/Pridor 2000Kms( i drain it at 1500 kms)
    Gear shifts are smooth,,reduced engine noise,,and in its price range good value for money
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  12. #12
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    hmmm, may be.
    yeah right bro & good info about latest grades
    Quote Originally Posted by humayun990 View Post
    Amjad bro,
    Humayun bro this is very short in market not available in my city not even at shell pumps
    but i had seen this oil in hyderabad but believe it looked fishy to me
    Quote Originally Posted by shazimzahir View Post
    Regards,
    thanks bro yeah fake oils are hard topic
    and it is really hard to determine which is fake or which is original
    the best thing possible we can do is we should purchase from big known dealers in city
    just today i purchase oil for my bike & generator the guy is having pretty good shop good variety of
    engine oils available at him oil bottle seems pretty nicely packed & cleaned new
    and i saw packets of companies he was saying companies vehichle come & deliver these to us
    Sir don't worry you won't get fake oil from us
  13. #13
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by devilskreed View Post
    Now this one is really hot product available in market
    really i am really to try this inshAllah will try to order few bottles online
    Devilskreed bro can you send me details of shop owner so that i may contact him
    and yaar really need your help i am very confused these days
    bro how do you measure quantity of oil for your bike i use engine oil bottles
    in which marks are given & how & when to check bike engine oil level
    yaar one thing has confused me some time i am getting accurate levels
    some time wrong today i bought servo engine oil marks on bottle were given
    i filled around 0.75lt or little above as par bottle markings but don't know
    why bike dip stick is showing low engine oil level
    level is little bit down from center marker or just touching it
  14. #14
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Default Servo M5
    Motorcycle Engine Oils -1241639
    Motorcycle Engine Oils -1241640
    Motorcycle Engine Oils -1241641
    Motorcycle Engine Oils -1241643
    These kinda branded name seals look good to me than whitish seal
    Motorcycle Engine Oils -1241642
    Price 220 Rupees For 0.7lt & 350 For 1.0lt
    And Plus You Will Get Two 5 Rupees Coin Inside The Bottle (Bribe From Company
    Update: This Is Low Quality Engine Oil Made For Chingchi & Rickshaw Drivers
    You Can Find More About This Story On #33
  15. #15
    gull_s_777's Avatar
    Feb 2012
    Bahawalpur
    2,279
    90 Post(s)
    7 Thread(s)
    [FONT=comic sans ms]Now this one is really hot product available in market
    Indeed it is. Too bad it isn't widely available.
  16. #16
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    I have used this oil in the past although it is one of the best oils but its too viscous that is to say 20W so it can damage engine in winters during cold starts i think that 10w-40 should be used in winters and 20w-50 in summers
    But as i said no doubt its a damn good oil
  17. #17
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Motorcycle Engine Oils -1242006
    guys just yesterday i bought this oil for my bike pridor 100
    as you can see there measurement marks given on bottle so believing on
    them i filled round about 800ml just slightly lower than 800ml
    but i was very confused i was consistently getting inaccurate oil level on dip stick
    as asked for help from devilskreed but he is busy
    Today at morning i tried to check oil level on different conditions first when bike was completely cold
    got inaccurate low level than tried as recommended in manual
    manual says start the bike let it run for few minutes & switch off bike ( bike should be on center stand)
    after few minutes open oil stick & take out clean with cloth than insert it in hole to check oil level but without tightening
    ya choori tight kare beghair than take it out check the level
    Did exactly the same and again got the inaccurate levels i was very tensed consulted with mechanic friend
    he said immediately fill more bottle marks must be inaccurate so don't care for them fill the oil immediately in bike
    so came bike home filled the oil to upper level exactly & now i am more relaxed
    bike was getting very hot with low oil mechanic also said that do you see how much hot is engine
    So Bottom Line Is Guys I Was Betrayed By The Marks Given On Bottle
    Screw AHl There Is Lot Of Confusion In Pridor Oil
    From Now On Would Trust On My Eyes & Oil Dip Stick
  18. #18
    faiz.aslam.121's Avatar
    Jan 2013
    Oslo
    21
    7,464
    5
    148 Post(s)
    4 Thread(s)
    Going to get Liqui Moly 4T for my CG-125 after Eid then
    Never trust quantity marks on a bottle- Always trust dipstick.
    Turbo lag is like foreplay. You know it's coming. And it's gonna be good.
  19. #19
    waqas.sh's Avatar
    May 2013
    Rawalpindi
    Bro,
    Can you please tell where i can buy Kixx engine oil from RWP/ISB? also which grade to be used? 10-40, 15-40 if available? thanks much for your time
  20. #20
    Majidkhan567's Avatar
    Dec 2012
    413
    2 Post(s)
    i am using castrol GTX its awesome
